Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Electrical Systems
Old 01-11-2019, 10:28 AM
iamtheari iamtheari is offline
Default Selectively Latching Momentary Switch Circuit
This is for my smoke system. I plan to have an enable/disable switch on the panel, but I want the on/off control on my stick. I have a flashlight that works how I want it to work, but my one semester of EE courses in college didn't cover this.
The flashlight has one momentary button. When you tap it briefly, it latches the light ON. Tap it again to turn the light OFF. But if you hold the button down for more than about a half second, it just shines the light until you release the button.
I don't want to disassemble this particular flashlight to try to figure out the circuit. Does anyone have ideas on how to wire such a thing up without needing a microcontroller? I can make a latching circuit easily enough, but the dual function is beyond me.
Old 01-11-2019, 11:01 AM
lr172 lr172 is offline
Your flashlight does that through digital processing/logic using only a momentary switch. Not sure how you can replicate that for your application.
N64LR
RV-10 in progress
Old 01-12-2019, 05:04 AM
Someone on the AeroElectric List might be able to design a circuit for you.
Joe Gores
RV-12 Flying
Old 01-12-2019, 07:02 AM
maniago's Avatar
maniago maniago is offline
What Larry said. Its done with a freq clock and a counter. Its digital logic. We didnt do digital circuits until second year EE...tho in reality I didnt learn proper digital design until I went to work doing it. However, if you built it it would have to be out of discrete components and it would be bulky, and probably suseptable to stray static electricity; not what you want for your smoke system - the flashlight guys built the functions into a chip they designed and sent out for fab, MOSAIC style.....if they even use that anymore.
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI,wet compass
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 01-12-2019, 07:18 AM
That makes sense to me, that they would design a chip for their flashlights and have it mass-produced. It's a shame that Vertical Power won't let us reprogram the VP-X firmware to do things like this. Of course, that's one of those "what could possibly go wrong?" ideas that is better left on the drawing board.
Old 01-12-2019, 07:53 AM
I'd try to give a bit more thought to how it would operate while you're actually flying, before pursuing implementation. A pushbutton with no physical feedback of its condition leaves you without knowledge of its state. If it's a light in front of your eyes, great (maybe). But if its smoke out the back of the plane....
I'd find it easier to use a toggle or rocker switch that was center-off, momentary on in one direction and latching on in the other.
Just another perspective, FWIW.
Charlie
Old 01-12-2019, 10:58 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I think with some thought it could be done with some resistors, capacitors and a D flip flop or two. However, I think you are over complicating things unnecessarily. You would also need a logic power supply and drivers or relay to control the system.
Consider a mom-off-on toggle switch or slide switch. (On)-off-on.
A mini would fit on the stick.
KISS
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage in progress.
Old 01-12-2019, 11:28 AM
Default arduino
An arduino (or clone) would be able to accomplish this with some basic coding...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 01-12-2019, 01:44 PM
az_gila's Avatar
az_gila az_gila is offline
KISS
Sometimes the simplest solution is the best...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-12-2019, 01:57 PM
Any chance of just lifting/transplanting the circuitry from the flashlight-----and using it to control some magic electronic widget capable of handling the current of the smoke system??
