Old 01-06-2019, 07:32 PM
iamtheari iamtheari is offline
Default Engine mount grounding
The hardware bag for the engine mount was backordered in my finishing kit so I can’t actually put it on my plane yet. But I did prepare it for installation and came up with a question. The plans say to file four of the bolt holes down to bare metal to electrically bond the engine mount to the fuselage. That will electrically bond the engine mount to the bolt, but not necessarily to the fuselage. I primed the longeron assemblies. Should I sand off primer beneath the engine mount nuts, or does the bolt through the hole in the firewall do a good enough job?
Old 01-06-2019, 09:25 PM
mturnerb mturnerb is offline
There's a grounding strap engine to mount. Section 43, pages 05 and 08.
Turner Billingsley
RV-14A FLYING!!
Old 01-06-2019, 10:22 PM
Thanks. That sets my mind a bit at ease about the results of the step Iím questioning. I am still curious about the step itself, though, which call for filing off powder coat specifically to ensure an electrical bond between the engine mount and fuselage. The ground strap seems like the better solution to that problem and itís already part of the plan, so why the focus on filing off the powder coat here?
Old 01-06-2019, 11:33 PM
gasman gasman is offline
Originally Posted by iamtheari View Post
The hardware bag for the engine mount was backordered in my finishing kit so I canít actually put it on my plane yet. But I did prepare it for installation and came up with a question. The plans say to file four of the bolt holes down to bare metal to electrically bond the engine mount to the fuselage. That will electrically bond the engine mount to the bolt, but not necessarily to the fuselage. I primed the longeron assemblies. Should I sand off primer beneath the engine mount nuts, or does the bolt through the hole in the firewall do a good enough job?
I don't see the need to ground the engine mount to the firewall when the Lord mounts will isolate the motor case from the mount.
I would ground from your firewall battery ground bolt, to the motor case with a very good cable. I used welding cable with crimped and soldered eyes. And a second one from another firewall location. If your motor ground fails, the starter ground path will be through your engine control cables.....
The cable ends did have proper soldering techniques and heat shrink to avoid flex failure.
VAF #897
2019 =VAF= Dues PAID
Old 01-06-2019, 11:41 PM
I think that is a misprint.
The actual reason is because powder coat is not very hard.
The small contact area on edge of the tube will quickly compress the powder coating and reduce the loading on the bolt.
Scott McDaniels
Hubbard, Oregon
Old 01-07-2019, 01:12 PM
That makes more sense to me. Thanks. I just looked in section 40A and the tri-gear instructions don't say anything about this. Page 40B-02 step 3 says of the filing, "This will ensure that the engine mount is electrically bonded to the fuselage." Obviously I filed it off no matter the reason, but now I can comfortably build on without sanding primer off the longeron end pieces...once I get the bolts, that is.
Old 01-07-2019, 01:49 PM
Mike S Mike S is online now
Yep, this...
Old 01-07-2019, 02:28 PM
Avoca1us Avoca1us is offline
This omission in the tri gear instructions is a serious one. The battery is grounded to the firewall, and the engine is grounded to the engine mount. The engine mount must be electrically connected to the firewall for the engine ground to reach the battery.
Old 01-07-2019, 02:44 PM
DanH's Avatar
DanH DanH is offline
Forget grounding to the mount. Run one of these...
http://www.bandc.aero/braidedbondingstrap.aspx
...from the engine case ground point (on the right rear) directly to a firewall mounted forest of grounds (link to 48 tab example)...
http://www.bandc.aero/groundblock48-tab.aspx
...and ground everything there.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-07-2019, 03:20 PM
rv7charlie rv7charlie is online now
Not the best plan for a number of reasons.
Potential to magnetize the mount. (Fun with whiskey compass swinging)
More failure points, with corrosion prone materials, between engine and ground.
Potential for somewhat higher resistance path than needed when starting (steel instead of copper).
Probably more, but I'm lazy at the moment.
What Dan said, or just pick up some welding cable, as someone else mentioned. Almost as flexible as the braid, and comes standard with a non-abrasive coating. :-)
Charlie
