Old 01-12-2019, 04:04 AM
Daida Daida is offline
Thanks for your reply, but the antenna coax and the GPS wites are seperated in my case.
I have the feeling as if some “squelch”/channel opening gate is set too low or the antenna(or a cable) is constantly receiving as i can hear my 12V LED Strobes when i turn them on as well.
Or i screwed up my wireing elsewhere.....
Anyway, I have contacted Dynon via their factory homepage and awaiting their answer.
Thanks anyway!
RV-8 QB Germany
metal work complete
ECi XIO-360 installed
Dynon SV
Wings+Empenage+Fuselage=Plane
Final touches....
Almost there!
Old 01-12-2019, 07:13 AM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Didn't want to pile on...
I have been monitoring this thread, but didn't want to pile on as others have been giving some good advise regarding the grounding issues. I do have some questions? With regards to the intercom install, is it our wiring harness? How are the strobes grounded? When you say it quits with the X83 un-powered, is the intercom still powered? I will also reply to you when I am back at work on Monday and can do some research, but will also keep this thread updated as well in case it may help others.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 01-12-2019, 03:10 PM
Hi Don,
thank you for response.
Here are the answers to your questions.
It is NOT your wiring harness, i made up my own. Only the network cables are the factory ones.
Strobes are grounded at the forrest of tabs (FOT). (a single wire grounds COM T8 PIN 22, PIN 19 and PIN 2 COM PANEL there as well)
The intercom was not powered.
I still have to check if PIN 1 from the INTERCOM S2 is solely connected to PIN 1 from the COM T8 (as shown on page 17-11 SV installation guide). I may did it wrong and ran a wire directly to the FOT/ground as shown in the S2 installation guide page 2-3?
Plane is 30min drive away from home. I will find out and post what i find out.
So long...
RV-8 QB Germany
metal work complete
Dynon SV
Final touches....
Almost there!
Old 01-23-2019, 12:12 PM
Default Problem solved!
I was at the hangar, chasing the gremlin.
Finally succeeded and got rid of it!
I had a ground loop!
I wired it up the wrong way.
PIN 1 from the INTERCOM S2 was NOT solely connected to PIN 1 from the COM T8 (as shown on page 17-10 SV installation guide). I additionally ran a connection from INTERCOM S2 PIN 1 directly to the FOT/ground (as shown in the S2 installation guide page 2-3) which closed my ground loop.
As i am not a professional, i guess i interpreted the drawing incorrectly.
Problem solved. Case closed.
Thanks everyone for your inputs!
RV-8 QB Germany
metal work complete
Dynon SV
Final touches....
Almost there!
