Old 01-05-2019, 02:04 PM
ColoradoSolar ColoradoSolar is offline
Default Length of Wing
I am trying to get my tools lined up and my workbenches built before I go down the path of my 14 build. That leads to a couple of questions.
1. If I want to build both of the wings at the same time how many clecos will I need?
2. How long is one wing? I am going to be building modified versions of the EAA workbench but I want to make sure the whole wing will fit.
Old 01-05-2019, 03:07 PM
control control is offline
That would be one long bench!
I do not have the measurement now but I would anyhow suggest that you build two benches and have some air between them. I think I have around 300 of the #40 clecos (silver), worked for me when I had both skins on, you can probably get away with fewer as you really do not need to cleco every second hole on the wing that you are nor about to rivet at any given time.
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 01-05-2019, 04:57 PM
Scott Hersha Scott Hersha is offline
How many clecoes?..... all of them. I had to borrow a few. I built one work bench 10 long, and that worked out fine. Once I had the skeletal structure completed, I made two jigs that held the wings vertical, nose down right next to each other. I was able to get on either side. I had help riveting (back riveting, actually) the top skins on.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 01-05-2019, 05:23 PM
mturnerb mturnerb is offline
Wings without tips are about 10 to 10 1/2 feet
Turner Billingsley
RV-14A FLYING!!
Old 01-05-2019, 08:02 PM
Thanks for the replies. It seems like the kits from different vendors have differing amounts of clecos. One had 325 and one had 500.
Old 01-05-2019, 08:42 PM
Ironflight's Avatar
VAF Moderator / Line Boy
No matter what you end up with for clecos, be glad you’re building an RV - we finished up the wings for our all-metal motorglider last fall and used every cleco in captivity at our airpark! Each wing was 24’ long with the spar stubs....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
