Old 01-04-2019, 01:19 PM
Cirrus Man Cirrus Man is offline
Default Viking 130 Engine in RV-12
Has anyone installed a Viking 130 Engine in their RV-12.
I purchased a Viking 130 Engine, but have had some minor install issues.
Old 01-04-2019, 01:20 PM
Default RV-12is Upgrades
Has anyone installed some of the "many" improvements made to the RV-12is in their RV-12?
Old 01-04-2019, 08:10 PM
12vaitor 12vaitor is offline
I have a Viking 110 installed in my RV-12. It appears there are a couple of RV-12s with the 130, however I have seen no information on flying characteristics, final W&B, or increased gross weight needed to get a useful payload number. From what I could find, it appears the 130 was about 25 lb heavier than the 110 and the CG was an additional 6 inches forward. Both are a bad combination in an RV-12. I am sure the nose wheel weight will be pushing 215-220 lbs and the CG will be near/past the forward limit with fuel and a single pilot. With the 110, I ended up moving the dual fuel pumps to the tail cone (like the RV-12is) along with the dual batteries to get forward CG in limits with single pilot at minimum fuel.
Modifying the forward longeron ends for additional engine mount attachments and the belly radiator under the footwells are more evidence you are going to have some serious W&B issues to overcome with the 130 engine.
The 130 might be a good engine for an RV-9, I believe someone built one in the past couple of years and reported good numbers.
John Salak
RV-12 N896HS
