Old 01-03-2019, 08:29 PM
8 Builder 8 Builder is offline
Default Canopy Latch problem
I have a situation where when I trimmed the canopy latch and it seemed to be just right. It did not try to pull the canopy closed more than the pin seated in the block allowed it to close. When I attached the spring the trouble started. The spring wants to open the latch. I can't imagine that this can be right but it looks like the spring is attached correctly. Sorry picture upside down.???????
Rich Snyder
Building RV-8
Superior IO-360
Garmin G3X Touch VFR
Planning for Fixed Catto 3 blade
Old 01-04-2019, 02:14 PM
Champ's Avatar
Champ Champ is offline
I not sure what the plans call for on the spring location but mine is on the other side. The latch works perfectly. Note the paint worn off on the canopy bow is from the latch hitting in the over closed position when the canopy is open - I should be more careful and will touch this up some time.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2019 Donation In
Old 01-05-2019, 12:05 PM
Default Problem solved
After getting some advice from Eric at Vans builder support, I re-did the latch arm and did not trim it as much. The extra pressure needed to make the frame close more was all it took to make the latch stay closed by itself.
Rich Snyder
Building RV-8
Superior IO-360
