Old 01-03-2019, 12:08 PM
kbalch's Avatar
kbalch kbalch is offline
Default Substitute AN426 for AN470?
29-20 Step 5
In an uncharacteristic episode of carelessness, I managed to countersink the aft four holes meant for AN470 rivets - on both sides, no less! Can I substitute AN426 rivets with impunity?
Ken
RV-8 N118KB (sold)
RV-14A #140494 (Finish kit in progress)
N114KB (reserved)
Old 01-04-2019, 06:18 AM
shanecfi shanecfi is offline
Default Counter Sink
I don't think countersinking is bad in this case. I did the same thing early on during the Vertical Stab build. I called Vans and they said use 426's and build on. What would concerns me, is by both sides, do you mean right and left or top and bottom sides, of part F-01457-L? If it's top and bottom I would order a new part. If right and left I would build on, after a call to Vans.
Shane Barker #140351
Commercial/Instrument
EAA/AOPA
RV-14a Emp. completed and stored
Wings Skins completed and stored
Fuselage joined
Old 01-04-2019, 07:13 AM
kbalch's Avatar
Yep, I agree with all of that. By "both sides" I meant left/right. I've moved on and have now completed Section 29 - less the air vents, as I'm waiting for the arrival of the aluminum units.
A little work on the tailcone today while it's still relatively accessible (-01406 bulkhead components, bottom skin SB, and installation of pitch/yaw servo brackets), and I'll be ready for the big "join" tomorrow morning. Progress!
Ken
RV-8 N118KB (sold)
N114KB (reserved)
Old 01-04-2019, 07:30 AM
mturnerb mturnerb is offline
I did exactly the same thing and used an426. Build on!!!
Turner Billingsley
RV-14A FLYING!!
