Old 01-01-2019, 07:26 PM
Draker's Avatar
Draker Draker is online now
Default Aft canopy deck position along the longerons
Happy new year everyone. Wish I could share in the happiness, but I just found what's possibly a catastrophic mistake I made on the RV, and wanted to share it. Obviously this is going to involve a long discussion with Van's, but I thought I'd start a discussion here to potentially prepare myself for the extremely bad news I have coming.
Long story short, it looks like I built the whole forward and mid fuselage around incorrectly bent and drilled longerons.
I'm at the point in the build where I'm disassembling the forward fuselage to prep the surfaces, dimple, and countersink them for riveting. While countersinking the longerons, something just didn't look right. The top holes I had drilled for the aft canopy deck were way too far aft. So I clecoed the longeron back to the mid-fuselage, and pulled out the F-721B aft canopy deck pieces. Lo and behold, the holes are indeed way too far back:
It looks like way back when I drilled the canopy deck to the longerons, I had the forward edge of it in the wrong position:
How I made the mistake: The distance between "Beginning of Curve" and "End of Curve" is 30 27/32" which is almost exactly the length of the F-721B canopy deck piece, so I ASSumed that it was to be positioned between these marks.
So at the very least, I'm going to be ordering two more longerons, re-bending them both, and re-drilling them to the skins. As a side note, the holes in the longeron-facing aft fuselage skins are already dimpled so it's not going to be fun to re-drill those. But that's the least of my problems.
Unfortunately, as a result of incorrectly locating the canopy deck pieces, my longerons must have been bent in such a way that they align with the incorrect placement. As proof, when I lay the canopy deck piece against the longeron in the correct position, it does not match up with the curve of the longeron:
This means I have built the entire forward fuselage around incorrectly bent longerons. This may mean that I'm scrapping a fair bit of the front fuselage, too, likely at least the side skins.
To say I'm disappointed is an understatement. Please help me brace for the bad news from Van's. I'll be calling them pretty much as soon as they re-open from the holidays. And future builders, please learn from my carelessness.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 1/2/2019
RV-7A: Empennage and wing kits complete minus fiberglass, fuselage in progress!
Old 01-01-2019, 07:40 PM
Can you not "simply" replace the longerons? Most everything else is already match hole punched and should fit right back together.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-01-2019, 07:50 PM
wirejock's Avatar
wirejock wirejock is offline
Default Longerons
Agree. Everything else is prepunched. You may find the right size and type of angle at a local metal distributor. Check with Vans but I think it's 6061 T6 extruded angle. Note the curved inside vertex.
I have had to drill using a dimpled part before. Buy a section of brass tubing (1/16") that perfectly fits the dimpled hole. Use it as a drill bushing to keep the bit centered.#41 should fit.
Hope it works out.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-01-2019, 08:20 PM
wjb's Avatar
wjb wjb is offline
Ryan and I spoke on the phone (we are both local NorCal builders) ... my assessment, too is it's just a longeron replacement. I'm hoping we can find a local supplier with stock so to nix the surely huge shipping charges...
We'll hear what Van's sez tomorrow.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Draker's Avatar
Yea, I'm hoping that's it. If it's just new longerons I'm going to be relieved. All of the non pre-punched parts (lower longeron, aux. longeron, side skin stiffener angle, floor stiffeners) are in the forward area, which hopefully the incorrect bend does not affect.
Ryan Drake
Livermore, CA
Donated 1/2/2019
Old 01-01-2019, 09:05 PM
pilotkms pilotkms is offline
Look at the bright side - bending the second set of longerons will be much easier than the first. Donít ask how I know.
Keith
RV 7A RV #9700
N325KS the Flying ďKĒ
Built in SoCal KCCB, now @ KPXE
250+ Hours & 5x cross the USA
2018 OSH - yes
Old 01-01-2019, 10:31 PM
rackley16 rackley16 is offline
Ryan, I am sure you are in good company as there have been many mistakes made over the years in building many RV's. Someday you will look back and smile about it, I am sure. I have been where you are with other projects and honestly, the worst part was how bad I would beat myself up over it.
I do thank you for having the stones to stand up and show it. Just doing that will help some other guy down the road. That's what this forum is all about. Helping one another.
Good on ya! Ben
Ben
2018 dues paid.
RV7 empennage acquired and the "journey" has officially begun.
Old 01-02-2019, 08:41 AM
jcarne's Avatar
jcarne jcarne is offline
Yep I'm thinking just longerons too. Sorry to hear this happened. Keep us posted.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 01-02-2019, 10:54 AM
rapid_ascent rapid_ascent is offline
Ryan,
I sent you an email.
Ray
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 01-02-2019, 12:56 PM
Girraf Girraf is offline
Good on ya! Ben
I represent the guy that this guy is talking about. Iíll note your experience to hopefully avoid the same mistake when I get to this part of the build. Iíve also chosen to order two extra longerons with my wing order because I donít trust myself!
RV-7:
Working on Empennage
Wings Delivered
