Old 12-31-2018, 05:56 PM
subpar_bucker subpar_bucker is offline
Default RV-12iS fuel line photos
I wanted to send a quick post our showing the installation of the fuel lines I purchased from Aircraft Specialty. I've created a shared google photos album (hopefully that works).
https://photos.app.goo.gl/YCMMoV3YdnFKXZWc7
I can say it was quite delightful after humiliating myself fabricating the long fuel lines to simply attach these lines where they belonged in a single attempt
Old 12-31-2018, 06:13 PM
I'll stick with my two carburetors and deal with sinking floats.
iS plumbing looks like nightmare...
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 12-31-2018, 09:45 PM
rv9builder rv9builder is offline
Looks good, Bob! I can see where the pre-made lines will save a lot of time.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 12-31-2018, 11:01 PM
pilotyoung pilotyoung is offline
Default IS
That is amazing!
John D. Young, RV-12 Owner
Serial Number 120022, N6812Y
Bought it as a flying airplane in Feb. 2018
Just passed 100 hours flight time in RV-12, and 10,000 hours mostly in corporate jets. I am a CFI; CFII; MEI; and a advancd Ground Instructor, CFIG; and hoping to be able to help new RV-12 owners by doing some transition training for new builders and owners in RV-12's.
Old 01-01-2019, 11:02 AM
Tony_T's Avatar
Tony_T Tony_T is offline
Our little Chevrolet has evolved into a Mercedes!
That fuel pump/filter module looks like it could feed an SR-71 engine. OK, maybe that's an exaggeration .
Maintenance of the filters and pumps at annual will be problematic. And once the tailcone is installed fixing any leaks will be a challenge.
It looks like the only access once the tailcone is installed will be through the baggage bulkhead and work around-the-corner, so to speak? It looks like a small person could climb over the fuel tank to get back there but more likely the MM will call for removing it.
It will be interesting to follow the experience with the new airplane and it's many changes. The complexity reinforces my opinion that the iS should be a separate category in the forums.
Tony
RV-12 #202 -- Flying
Old 01-01-2019, 11:26 AM
I think there is an outside access door on left side behind rear baggage bulkhead - but still looks like a pain to do inspection/repair...
Hinckley, Ohio
EAA #499867
Old 01-01-2019, 11:31 AM
The iS version of the RV-12 has an access cover added to the bottom of the tail cone, directly below the fuel pumps.
Scott McDaniels
Hubbard, Oregon
Old 01-01-2019, 11:51 AM
Tony_T's Avatar
Yes, I forgot. But it is rather small, you could get maybe one hand though:
Has another access panel been added? It would take a pretty big access panel to get to all of this from the bottom of the aircraft?
Tony
Old 01-01-2019, 12:09 PM
That's the access cover for the fuel injection pumps, filters, and associated plumbing located behind the baggage rear bulkhead???
I guess maybe take a few pics before attaching the tail cone...
Hinckley, Ohio
EAA #499867
Old 01-01-2019, 12:26 PM
I'm not sure what you mean by "get to all of this". Everything you see can be reached through the designed opening. For those that want to stand behind the pumps when working on them, you will have to remove the tail cone I guess.....
The only item that needs to be removed during inspections is the black Andair prefilter.
The silver Rotax filter (up near the top) gets changed initially at 100 hrs and then 200 hr intervals after that. It would be difficult to change working through the bottom access hole, so that is best done through the baggage bulkhead opening.
I am not a young guy anymore but I have had no problem accessing it that way. In our shop we have a piece of plywood that fits the baggage floor. Because of the different fuel tank design, with the seats removed, it is possible to climb into the baggage area and sit on the baggage floor while accessing the fuel pump assembly (may require a tail stand to prevent he fuselage tilting onto the tail).
Scott McDaniels
Hubbard, Oregon
