Old 12-28-2018, 11:31 AM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Default HS-00003 Material
Does anyone know what material The spar Doubler HS-00003 is? Iím going to have to make my own I canít get the edge distance from the ones provided in the kit.
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 12-28-2018, 12:29 PM
Blake Blake is offline
Call vans they will sell you a blank sheet of aluminum that they make the doublers out of. I did that because I had to make one doubler from scratch to finish my rv-7 horizontal stabilizer
Old 12-28-2018, 01:02 PM
nzrv8's Avatar
nzrv8 nzrv8 is offline
Just checking that you've seen the edge distance amendment added to the SB? (Page 21).
I had an old version of the SB and ended up replacing my doublers without needing to. The amendment states a lower ED margin (lower than mil spec) and adding extra rivet locations in the event that the ED's aren't met. Might save you some re-work..
Paid up - Dec 2018
