Old 12-22-2018, 04:48 PM
Draker's Avatar
Draker Draker is offline
Default Forward fuselage floor stiffener gocha
Fuselage builders: Here's a gocha to watch out for. Don't make the mistake I just did.
When drilling the F-772B-R&L floor stiffeners to the F-772 forward bottom skin, the plans have you to draw center lines on the angle to help you align them with the pre-punched holes in the skin. I did this and dutifully match drilled them through the skin.
I did not read the next step until it was too late. You have to drill the sides of these stiffeners to the F-601J angles on the firewall. Well, by following the 'center line' directions, I've ended up with 7/64" gaps between these parts now:
I thought about asking Van's if I could put a shim in there and build on, but then wait! These stiffeners are just plain ol' AA6-063 3/4" angles with the ends all bent up. I've got tons of that. I could just re-make a new pair and re-drill them (not along the center line this time, obviously). That's probably what I'll do.
This is a public service announcement: READ AHEAD IN THE PLANS!
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 1/2/2019
RV-7A: Empennage and wing kits complete minus fiberglass, fuselage in progress!
Old 12-22-2018, 05:12 PM
wirejock's Avatar
wirejock wirejock is offline
Default Gotcha thread
Good one Ryan. Would you post that to the 7 "Gotcha" thread or maybe the Moderator can move it.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-22-2018, 07:32 PM
Draker's Avatar
Good idea. I've added this to the main gotcha thread.
Ryan Drake
Livermore, CA
Donated 1/2/2019
Old 12-22-2018, 09:14 PM
rapid_ascent rapid_ascent is offline
You might be able to just bend the flange out a little too. These pieces aren't too expensive from Vans though. I bought a couple "extras".
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-23-2018, 07:23 AM
Default Me
On my Rv9 ( same fuse as rv7) the side stiffeners had a really poor joggle. I cut them off and used another 3/4” angle nest with shimes. Much better result.
For these two bottom ones, i used the centerline for the outers and just had a min edge clearance line for the centers; i didnt try and put the center stiffeners in the eXact middle.
There is extra angle that came in the wing kit, so no need to buy extra parts from Vans unles you want the factory joggle.
John S
Dues paid 2019, worth every penny
Fuselage 30%
