Old 12-21-2018, 08:43 AM
N804RV's Avatar
N804RV N804RV is offline
Default Fwd Cockpit order of assembly tips
Working on fwd cockpit. Wondering if anyone has tips or tricks as far as order of assembly.
Ken W.
Mount Vernon, WA
2018 VAF Supporter
Old 12-21-2018, 09:32 PM
VA Maule VA Maule is offline
Do the gear tower access modification you will be really glad you did!!!!!
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 12-21-2018, 10:47 PM
N804RV's Avatar
Has anyone gotten feedback from Van's on modifying the gear towers?
Ken W.
Mount Vernon, WA
2018 VAF Supporter
Old 12-22-2018, 05:19 PM
fl-mike's Avatar
fl-mike fl-mike is offline
  1. If you're going to use Grove gear, drill the extra holes in the floor in the gear towers for the improved brake line routing. (search if you're not familiar with this)
  2. make the gear tower cover mod.
  3. I used a stubby drill in the countersink cage to drill the lower longerons. Kept the holes nice and square. It's an awkward angle. Or you can just be careful!
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage in progress.
