Old 12-19-2018, 09:07 AM
bkervaski's Avatar
Default G3X Touch Autopilot Autotrim .. Hunting
I've followed the Garmin G3X Touch Autopilot tuning guide. The AP works great and doesn't seem to work to hard to do its thing.
As a last step have enabled the autotrim.
Occasionally, the elevator autotrim hunts the elevator trim trying to capture an altitude, especially on initial activation of the AP. This results in the aircraft over and undershooting the altitude for a bit.
Seems like a gain thing but the AP is actually working quite well.
If I put the plane at the altitude prior to enabling the AP it doesn't hunt and can keep it there.
Is this normal? I'm new to an AP with automatic trim, no frame of reference.
Thanks for any advice!
Progress: Flying!
Old 12-19-2018, 09:20 AM
Walt's Avatar
Walt Walt is offline
I just fixed an RV14 with a similar complaint, turned out the elevator was so stiff that the AP was having trouble overcoming the friction and kept over and undershooting. If your elevator doesn't "free float" than that may be causing your issue.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Brantel's Avatar
Brantel Brantel is offline
Should be rock solid.
I think one would notice this quickly in flight but I would double check that your trim control signals are not reversed.
Also check the airspeed threshold and speed percentages. I think mine are still on the defaults which seem to work well with my airplane. Yours may be too fast.
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 12-19-2018, 09:26 AM
bkervaski's Avatar
Elevator is very smooth and free. I would love to know what final numbers for the servos you had on this for comparison if it's not too much trouble.
Yea, did this already .. a bit scary when it starts pitching straight down
Progress: Flying!
sometimes simple airplanes are not improved by a complex trim system. keep an eye on the trim to avoid a runaway condition.
Old 12-19-2018, 09:28 AM
Brantel's Avatar
Old 12-19-2018, 09:41 AM
BCP Boys's Avatar
BCP Boys BCP Boys is online now
Default numbers
Bill,
These are the settings the I have in my -7. Pretty much solid but it may vary for you...
Roll Servo
Max Torque = 15%
Servo Gain = 0.40
Fine Adjust Amount = 1
Fine Adjust Time = 0.20
Pitch Servo
Max Torque = 30%
Servo Gain = 1.30
Pitch Gain
Min Airspeed Limit = 65 kt (or as preferred)
Max Airspeed Limit = 180 kt (or as preferred)
Vertical Speed Gain = 1.00
Vertical Accel Gain = 1.00
Airspeed Gain = 1.00
Airspeed Accel Gain = 1.00
Electric Trim
Airspeed Thresholds = 80 kt / 150 kt
Roll Trim Motor Speed = 100% / 25%
Pitch Trim Motor Speed = 100% / 25%
I've also seen some posts with these numbers - You just have to figure out what's it doing wrong before making your adjustment.
Roll Torque 30%
Roll Servo Gain 0.65
Pitch Torque 60%
Pitch Servo Gain 2.15
Min Airspeed Limit 60 kt
Max Airspeed Limit 170 kt
Amir
RV-7 QB - N174WM
Supporting VAF since the first visit
Old 12-19-2018, 10:30 AM
g3xpert's Avatar
g3xpert g3xpert is offline
bkervaski,
You should not see this behavior. When properly setup the autopilot should not hunt and should feel rock solid.
Please send us an email including your autopilot and autotrim settings as well as a flight data log of the autopilot hunting.
Levi Self
Team X Project Manager
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 12-19-2018, 10:49 AM
Walt beat me too it....
My first question was going to be how free is the movement of the elevator?
Often times what people think is free and no friction (they are usually comparing to certified airplanes they have flown), is far from that.
Scott McDaniels
Hubbard, Oregon
Old 12-19-2018, 10:54 AM
Bavafa Bavafa is offline
Here is my numbers for the A/P setting and I don't believe it hunts at all.
Roll Servo •Max Torque 50%
•Servo Gain 1.20
•Pitch Servo •Max Torque 50%
•Servo Gain 1.40
•Pitch Gain •Min Airspeed 65 kt
•Max Airspeed 190 kt
•Vertical Speed Gain 1.50
•Vertical Accel Gain 1.50
•Airspeed Gain 1.50
•Airspeed Accel Gain 1.50
•Trim •Airspeed Threshold 100 kt/150 kt
•Roll trim motor speed 100%/30%
•Pitch Trim motor speed 100%/40%
•Roll Auto Trim Min Speed 10%
•Pitch Auto Trim Min Speed 5%
For trim run time, I have set it to 6 seconds. Initially was two seconds and it was not nearly enough. I feel the elevator a lot heavier than RV7 but only in flight and specially in the higher speed. I have no idea if this is normal for the 14 and expected. It is free and smooth on the ground and feels like the 7 (on the ground)
For my roll, I have not set any limit time as it is not nearly as sensitive to adjust.
I have confirmed that my auto trim works.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
