Old 12-20-2018, 09:50 AM
starkw1 starkw1 is offline
Default Dynon Servo shear screw replacement
I had broken shear screw on the pitch and roll servos in my -7 this past summer. At first, I noticed that the AP would not hold altitude, occassionally at first, then more frequently. After I replaced that shear screw, I discovered the shear screw in the roll servo was also broken when I was trouble shooting a frequent AP disconnect. No AP flight anomolies associated with the broken roll servo shear screw that I could detect; the frequent AP disconnect was apparently due to some conbination of a faulty roll servo circuit board and/or intermittant ground.
Dynon indicates that their new shear screws are more robust that the early ones.
Warren
RV-7, 300 hrs
Minneapolis
Old 12-20-2018, 08:09 PM
Any idea of when Dynon went to the new more robust design?
Old 12-21-2018, 06:41 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default New Design Shear Screw
The new design shear screw was available late in the 1st quarter of 2017. It was a redesign due to a premature fatigue failure of the old design screw during normal use.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 12-21-2018, 11:07 PM
ben barron ben barron is offline
With a call / email to Dynon tuesday, they sent the new roll servo shear screw via USPS so i recieved it 2 days later. The part came with lockTite, Allen wrench and cotter pin all at no cost. Thatís great service.
It was Easy install in place.
My question now is with a 2015 vintage servo should i be changing out the pitch servo shear screw? I would like to avoid failure in flight when i need it.
B2RV12
Old 12-21-2018, 11:29 PM
Ben,
Same thing I am thinking. My servos were installed in 2012 and have 800 hours on them. Sounds like I should replace them at annual.
Rich
