Old 12-18-2018, 03:04 PM
ben barron ben barron is offline
Default Dynon Servo shear screw replacement
My roll servo stopped working on my last flight. Jeff at Dynon gave ma a simple test to confirm it was a failed shear screw, which I did. I now need to install a new screw. Has anyone out there done this? Can it be done in place? The new screw goes in a new hole. Will the servo re-set it self as the arm will be in a different location to align with the new screw?
Dynon sends out (at no cost) a new screw when you reach out and then fill out a form. http://Www.dyninavioniocs.com/guides...t_instructions rev_E.pdf
B2RV12
Old 12-18-2018, 03:50 PM
woxofswa woxofswa is offline
I’ve replaced both pitch and roll, but it’s not a big deal. Yes you need to remove the servo but getting access is pretty simple. Which hole you use is immaterial as when you are finished, you’ll go back into the software and run the setup app again.
BTW, at least in the RV10 servos, the replacement screws are noticeably beefier than the originals and I haven’t had any issues since.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 12-18-2018, 04:12 PM
Appreciate the response...it does look like i may have access to do it in place on the RV12.
B2RV12
Old 12-18-2018, 05:49 PM
bruceh's Avatar
bruceh bruceh is offline
Dynon has an instructional video of the process:
https://www.youtube.com/watch?v=4wFEY3kT97g
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 12-19-2018, 07:16 AM
benfra benfra is offline
Smile shear screw
I was able to replace the shear screw in place on the aft "roll" servo. One has to remove the arm by pulling the castle nut ,this gives access to three screw holes, use a new screw hole for screw and locktite. The arm will reposition its self . Was a lot easier not having to remove the servo. Works Great, Good Luck RV 12
Old 12-19-2018, 10:07 AM
For you guys who had broken shear screws can you attribute it to anything unusual or is the design just susceptible to the problem?
Old 12-19-2018, 11:02 AM
DHeal DHeal is offline
A couple of years ago I sheared the pitch shear screw in my RV-12. This was due to my over-enthusiastic movement of the stabilator during a period of aerial messing about. The shear screw is easily replaced using the Dynon-supplied kit. At that time Dynon told me that they had strengthened the shear screw to make such issues less likely. No problem since.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 760+ hours (as of May 2019)!
VAF donation through June 2019.
Old 12-19-2018, 12:46 PM
Thumbs up shear screw
My shear screw broke because off runaway trim. I was correcting the condition before the autopilot was disconnected. My autopilot has been a problem trimming nose down and full left roll, so my immediate correction was needed! Dynon and I are fixing the problem. However it seemed to shear quite easily,worked safely and as designed. Ben
Old 12-19-2018, 09:56 PM
Thanks. I wanted to be sure Iím not doing something that might cause it to shear.
Old 12-20-2018, 07:49 AM
bobg56 bobg56 is offline
The old shear screws are easy to shear, I once had a pitch issue and when I went to check to see if the screw was loose, all I did was checking with an allen wrench and it broke with very little tension applied.
