Old 12-17-2018, 08:57 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default Converting -9A to -9
I am thinking of converting my trike to a taildragger.
1. Do you think I will need to re-do the wheel pants and main landing gear fairings?
2. Is their any risk or concern that the engine is no longer perfectly mated to the cowling?
Other than that I think it is pretty simple, perhaps the most time consuming will be disconnecting the engine, exhaust, controls, wiring, tie wraps, etc. involved with changing out the engine mount. I see that I will need to remove my tail tie down ring and bracket and install a WD-409 tail spring holder. I will leave my main landing gear brackets in place and just remove the gear legs. Probably need to reconfigure the brake lines. Should I start at the tail, or the engine?
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
www.mykitlog.com/dbro172/
1968 Mooney M20C - Sold
1956 C-182 - Sold
Old 12-17-2018, 09:09 PM
N941WR's Avatar
N941WR N941WR is online now
Do a search on the subject. This conversation has been done on both -7A's and -9A's.
The people who have done this will be able to answer your questions and give you a good insight into what to expect.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-17-2018, 09:45 PM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
Been there, done that. Definitely worth removing the old gear towers - more legroom and 15 pounds lighter.
Check (shown on plans) that you have the VS spar that has NOT been lightened, otherwise you will need to replace that, which means some disassembly and reassembly.
You will need to realign the wheel pants. Might be able to reuse the leg fairings, but will need realignment as well. Or you might have to buy/fabricate new leg fairings (9 legs are longer than 9A legs). Intersection fairings may or may not be reusable.
Engine will be fine unless you have some sort of odd engine mount that is not standard - at least mine fit perfectly with the new engine mount when I changed over.
Yes, will need to reconfigure brake lines, and may require new ones if yours are flexible lines rather than aluminum.
Happy to answer any questions you might have, either here or by PM/email.
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 12-17-2018, 09:51 PM
Dbro172's Avatar
I have a QB fuse, like yours. I purchased the tail wheel bracket so I can tinker with it and see how to fit it in the rear end. Bummer about the fiberglass, was hoping to not have to go there, with a painted plane and all... I cant remember, do I NOT need to unbolt the wings to remove the main landing gear brackets? I remember how difficult it was driving home the wing attach bolts and wouldn’t even consider removing the wing bolts, I think it would do more harm than good.
Derek Hoeschen
EAA Tech Counselor
1956 C-182 - Sold
Old 12-17-2018, 10:50 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I've converted my 7A to a 7
PM me with your cell# and we can chat about the whole experience.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1095+ hours
2018 Donation Paid
Old 12-18-2018, 07:52 AM
To respond...
The fuselage/gear intersection fairing needs to be replaced.
The gear leg fairing needs to be about an inch longer.
Yes, mine was mismatched. Others were not. Mine was more on the top cowling which was now short. I had to extend & realign the piano hinge
1095+ hours
2018 Donation Paid
Old 12-18-2018, 08:37 AM
cajunwings cajunwings is offline
Default 9A to 9
I removed the most aft double bulkhead to install the tail spring mount. The parts are inexpensive so I just bought new ones. While you are in there you should do the reinforcement mod around the inspection plate hole. I have photos I can send you.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 12-18-2018, 08:48 AM
Originally Posted by Dbro172 View Post
Unbolt (remove the nuts), yes; remove wings, no.
Greg Arehart
N 7965A
Old 12-18-2018, 05:07 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default 9a-9
I did the conversion from a 9a-9. I will pm you with my phone number
Al Girard, Newport, RI
N339AG
RV-9
Old 12-18-2018, 05:59 PM
rocketbob's Avatar
rocketbob rocketbob is offline
I have a bit over 2000 hours in tailwheel RV's and to be honest enjoy the easy landing qualities and great visibility in the flare of the 9A. Why change it?
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
