Old 12-18-2018, 02:24 PM
az_gila's Avatar
az_gila az_gila is offline
Red face
Originally Posted by RV7A Flyer View Post
Wait, how would that help? He needs to make the nut shorter (one option) in order to engage the hole in the axle. A shim effectively makes the nut *longer* (I used some peelable shim from McMaster on one axle that developed a little sloppiness a while back).
Correct, I was reading it as a close adjustment.... oops...
Sand the nut to make it fit, and then use a shim if you need to re-use the old hub.
It will be easier and less work than drilling new holes in the hardened steel axles, especially with the legs still on the plane.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
