Old 12-17-2018, 09:38 AM
dbegeman's Avatar
dbegeman dbegeman is offline
Default Cotter pin vs. safety wire
I need some help, I had the main wheel bearings replaced by antisplat and the result is a hub that is about an 1/8 bigger than the original. The cotter pin no longer lines up and I was advised to just sand down the axle nut so the cotter pin would fit. My question is, safety wire (doubled up) and wrapped around the nut fits without sanding, is this acceptable or am I better off sanding the nut down and using a cotter pin?
Dan
RV-6A
Navy Vet
Donation made for 2019
Old 12-17-2018, 09:50 AM
Richard@Langair Richard@Langair is offline
You could also drill new cotter pin holes in the axle. Just drill a bit offset from the original and you will be good.
Old 12-17-2018, 09:55 AM
Yep, this one.
Old 12-17-2018, 11:21 AM
Raymo's Avatar
Raymo Raymo is offline
Consider how easy it is to cut through safety wire versus that huge cotter pin, which is designed for shear strength.
The hole that is there now had to be drilled by the builder.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 12-17-2018, 11:29 AM
Ralph Inkster Ralph Inkster is offline
I have opened the cotter pin hole into a slot on numerous planes. It still effectively locks the nut and allows adjustment where sometimes the original installation didn't. & it still allows use of the 1/8" cotter pin.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 12-17-2018, 01:01 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Originally Posted by dbegeman View Post
I need some help, I had the main wheel bearings replaced by antisplat and the result is a hub that is about an 1/8” bigger than the original. The cotter pin no longer lines up and I was advised to just sand down the axle nut so the cotter pin would fit. My question is, safety wire (doubled up) and wrapped around the nut fits without sanding, is this acceptable or am I better off sanding the nut down and using a cotter pin?
Dan
If you don't want to sand the nut, use a shim.
One flat turn is equal to a 0.010 inch shim. Get a scrap of 0.020 aluminum and sand if down until you get the position you want. Sandpaper simply placed on a hard steel surface should do the job.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-17-2018, 05:58 PM
dbegeman's Avatar
So drilling another hole in the axle or widening the original hole would not cause any structural issues or cause any stress cracks in the axle down the road?
RV-6A
Navy Vet
Old 12-17-2018, 07:14 PM
Use a dremel tool to elongate the hole in the axle NUT. Or drill a new offset hole in the axle. Do not widen the existing hole in the axle.
Ralph
Old 12-17-2018, 08:50 PM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
I have two pairs of holes in my axle, as I change between wheel/tire sizes. Doubt it will be an issue as those axles are pretty stout.
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 12-18-2018, 11:46 AM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Wait, how would that help? He needs to make the nut shorter (one option) in order to engage the hole in the axle. A shim effectively makes the nut *longer* (I used some peelable shim from McMaster on one axle that developed a little sloppiness a while back).
2019 Dues paid!
