Old 12-12-2018, 08:54 AM
Draker's Avatar
Draker Draker is offline
Default Edge distance for F-796B
I've gone through a couple of angles, having a heckuva time getting correct edge distance on the F-796B angle that holds the fuel tank attach bracket. This angle nestles against the F-902 bulkhead in such a way that maintaining edge distance on the lower (#12 screw) hole is impossible. I'll see if I can get some pics of my "best" effort. Lots of scrap being produced on this one. Any tips? Anyone have a picture of a correctly constructed piece?
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 1/2/2019
RV-7A: Empennage and wing kits complete minus fiberglass, fuselage in progress!
Old 12-12-2018, 09:39 AM
wirejock's Avatar
wirejock wirejock is offline
Default F796B L&R
I have a couple photos and a description on my blog if it helps. I do remember it was a pain. More pain trying to get at the nuts. I made a set of this wall sockets for that. Buy sockedits from the Thrift Store and grind them down. Cheap tools.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 12-12-2018, 09:56 AM
Draker's Avatar
Thanks again, Larry. Yours actually looks as close to the edge as mine. Might have to double check my measurement. Iím still afraid once I open it up to #12 I bust distance.
Ryan Drake
Livermore, CA
Donated 1/2/2019
Old 12-12-2018, 10:19 AM
Default Who you gonna call?
I had the same dilemma, even ordered parts to remake. But a quick email to Vans and they replied with a return phone call and we found an adequate solution. Great service from Vans support. And now it is documented, so if there ever is a question, I have an official response.
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 12-12-2018, 10:44 AM
wirejock's Avatar
Default 796
Ryan
Keep us posted. If it's nested right in the space there's nothing else that can be done. A call to Vans to document as mentioned might be in order. I still think I hit the edge distance because I always mark parts before drilling.
That said, there's several places on the fuse where it was impossible and I asked Vans to confirm.
Larry Larson
Estes Park, CO
Disclaimer
Old 12-12-2018, 12:14 PM
mfleming's Avatar
mfleming mfleming is offline
So for all the builders that we see this thread and have the same dilemma ....please share Vanís solution
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 12-18-2018, 12:27 PM
Draker's Avatar
Advice from Vans was to get as much edge distance as possible.
If you do the math itís actually impossible to get sufficient distance:
According to the plans, the holes must be centered 15/32" from the forward edge of the angle. Since this is 3/4" angle, this means the hole must be centered 3/4Ē minus 15/32" = 9/32" from the aft edge of the angle. The plans also suggest the center of the hole is approx. 9/32Ē vertically from the top edge.
The final size of these holes will be 3/16" and #12. A 3/16" hole centered 9/32Ē from an edge leaves 3/16Ē edge distance which is obviously too small. Thatís the best case if youíre right on the money with your drilling. Best I got was 5/32Ē and Iím going to leave that as is.
Ryan Drake
Livermore, CA
Donated 1/2/2019
Old 12-18-2018, 09:53 PM
Tommy123 Tommy123 is offline
I can't understand why vans uses fractions when industry standard is thousands of a inch. It's not like the scales are rare.
I worked at falcon jet for a few weeks, **** millimeters!
