Old 12-16-2018, 04:28 PM
jcarne's Avatar
jcarne jcarne is offline
Most all SBs were in the kits I received over the last two years. That being said, definitely look at all the SBs and letters on Van's website, not everything worthy of knowing is in the SBs.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 12-16-2018, 05:28 PM
Girraf Girraf is offline
The instructions have been updated to reflect the doublers...I just checked. There is nothing in the SB that you HAVE to know since you'll be installing the doublers as you build (the SB is mainly for folks that need to retrofit), but reading it would fall into the "best practices" category. There no such thing as learning too much when it comes this this journey.
The one piece of valuable information that I did take away from the SB was on near the end (pg 17 maybe?) regarding edge distance. For the outboard most holes on the top of each doubler that get match drilled to the through the 702 spar and into the HS-710, edge distance of no less than 1.25D is acceptable (a deviation from the standard 2D). D in this case is the diameter of the rivet that will be set in the hole and the edge distance is measured from the CENTER of the hole, not from the edge of the hole.
Example: 1/8" rivet applying the 2D guideline requires that the edge of any material in which that hole is drilled is no closer then 1/4" to the center of the rivet hole.
Another tip worth considering is to build the vertical stab first. I actually paused my HS build and worked on the vertical for a period of time and found it much easier to assemble. The HS has a lot going in the center section and great care must be taken to get it all correct. Building the VS was a good confidence builder that made working the HS a more comfortable experience.
RV-7:
Empennage complete!
Wings in progress
Old 12-16-2018, 06:18 PM
nohoflyer nohoflyer is offline
Totally agree with this post. Start with the VS. I took a break from the HS too and the VS was a breeze.
RV-7A builder
A320 Capt at some airline
T-37/T-38/KC-135
C-177/172
Piper Warrior
Old 12-19-2018, 08:40 AM
Lefty37 Lefty37 is offline
Okay, I think I'm getting the hang of it now. I trimmed down the HS-702 allowing for the edge distance to the first hole. Then I fit it together with the HS-00001 and the HS-00005. After a few test fits and a few more passes with the file I got it to fit together like this. I think I might be getting the hang of this...
https://photos.app.goo.gl/iKcacQ6fkZNNcRr17
Old 12-19-2018, 10:28 AM
Looks good. I personally didn't trim any of the rib, but I don't see a glaring issue with doing that in conjuction with trimming the 702.
RV-7:
Empennage complete!
Wings in progress
Old 12-19-2018, 10:29 AM
wirejock's Avatar
wirejock wirejock is offline
Default Rivet hole
Memory may not be good but I seem to remember an unused hole there in the skin that required a bit more relief for the shop head to clear. Like I said, I might be mixing up components.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
