Old 12-13-2018, 02:53 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default photo
Great picture. That is probably the best installation picture I have seen for both the piano hinge and Archer nav antenna together. I plan to follow suit on the RV-14 when I get to that point. Thanks again.
Jon
RV-14A #140512:
Empennage Complete
Wings Ordered
Old 12-14-2018, 04:40 PM
JDA_BTR JDA_BTR is offline
Imitation is the sincerest form of flattery. My archer antenna is on the inside and here is the outside one tip done.
I have to say that working with the acrylic light cover is tough. It cuts easy with shears but finish sanding is a bear.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 12-15-2018, 06:35 PM
smash smash is offline
Instead of finish sanding the acrylic, just scrape with a single edge razor blade.
http://www.smashsrv-14build.com
Old 12-16-2018, 07:54 PM
How did y’all handle the wing tip rib installation on the w-1015-l/r part? I didn’t take that into account so now the hinge extends into that area. I suppose I can trim some hinge as a spacer to put under it or better trim the part to just be where the hinge isn’t?
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 12-16-2018, 09:44 PM
I swapped the left and right tip ribs and modified the flange to accommodate the hinge. You can view some of the details at this link:
http://www.smashsrv-14build.com/2018...-inserted.html
Old 12-16-2018, 11:14 PM
I think I will cheat it forward a bit and put a length of hinge on either side as a spacer. I will cut the loops off the spacers if I do that. Your way is good too though and I might have to change my mind because it puts the part in exactly the right place. But with the hinge spacer I think it moves it negligibly forward.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 12-17-2018, 06:29 AM
After sleeping on it I like your solution better. Will build it up tonight.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
