Old 12-08-2018, 11:30 AM
azflyer21 azflyer21 is offline
Default Classic Aero seat question
For those who have installed the Classic Aero seats in a -14, do I still need to install the Van's seatback hinges (F-01447B) since the CA seats have an integrated seatback frame?
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 12-08-2018, 11:40 AM
M McGraw's Avatar
M McGraw M McGraw is offline
If your asking about the hinges on the seat pan, yes. Also, you may consider not installing the rear most hinge. The Aero Classic seat has a 45* bend at the bottom where the hinge attaches. Causing the second from the rear to give the same leg length as using the aft hinge on the Vans seatback. Using the last hinge with the Aero Classic will cause a nearly vertical seatback.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 275+
2019 Dues Paid
The Dues Paid note is a reminder for me
Old 12-08-2018, 12:00 PM
KeithB KeithB is offline
Also, Classic Aero uses a wide hinge (1 more loop of hinge on each end of each seat hinge) than Vans standard install. One can replace the seat pan hinge with a longer one, or opt to use as is (which I did) leaving an un-attached loop on the seat back.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, 24th in the air, >400 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 12-08-2018, 04:19 PM
Thank you. This is a big help guys.
Kevin Lippert
Sold
N1402 reserved
Build Log
