Old 12-08-2018, 09:22 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Question Mounting GTX 345R
Where and how are folks mounting their GTX 345R? I have a rough concept, but would like to hear from others (RV-7A slider). Pictures would be greatly appreciated.
Michael
Danville, IN
RV-7A Fuselage
N317PU Reserved
2018 Dues paid (August 2018)
Old 12-08-2018, 10:05 AM
Mountain Time Mountain Time is offline
Default Good Question!
Iím putting a GTX45R into my 6 as part of a G3X Touch/GTN650 based panel upgrade, and Iíve been wondering the same thing - the other LRUs are small enough that finding a spot for them wonít be a problem, but the transponder is sizable enough that Iíve not yet come up with a good spot for it.
What say you experts whoíve gone down this path already?
John H.Wiegenstein
Hansville, WA
RV-6 flying, 0-360 CS, 500+hr
KPWT - Bremerton National
www.hellerwiegenstein.com
Old 12-08-2018, 10:47 AM
Mark33 Mark33 is offline
Iím installing the same unit in my -7 build. I donít know the exact location that Iím going to install it yet but I think it needs to be in an area thatís readily accessible. Out of all the rest of the avionics installed, the transponder is the one piece of equipment thatíll need to be able to come out on a regular basis to get checked. Iím planning on fabricating a couple of hinged fold-down trays between the sub panel and the firewall on which to mount all of my remote mount avionics, but I think Iíll probably mount the transponder on the bottom side of one of the fold-down trays just so itís easily accessible/removable.
Old 12-08-2018, 11:00 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Behind the subpanel
One place that works pretty well is behind the subpanel directly behind the primary display. You can make a reinforcement ring in the subpanel and cut out the sub-panel for the transponder to slide through. The mounting of the transponder is the same as you would mount it in the panel, i.e. I would use aluminum angle on either side of the tray and create an anchor strap to the rear of the unit. The transponder can then be installed and removed through the display opening in the panel.
Levi
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 12-08-2018, 11:03 AM
Walt's Avatar
Walt Walt is offline
I like the aft baggage bulhead location on the 7/9 if possible. Running the wires can be a bit if a challenge on a flying aircraft so they go up front sometimes depending on the setup. I also like having the short antenna cable run when its all in the aft section. My own aircraft has the old 23ES on the bulkhead, easy to get to and works great.
Steve's location above is also a good one, but easier to do when building than retrofitting, so it all depends.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 12-08-2018, 11:54 AM
Ian Coates Ian Coates is offline
I put mine underneath the VPX unit and attached it with small angle stock to the rails that were made as shown in the VPX installation, it sits sideways and slides in and out nicely.
VAF Donation 2019
RV7 Built and Flying
Old 12-09-2018, 10:52 AM
Good tips, gentlemen, I'll do some mockup next time I get to the hangar.
John H.Wiegenstein
Hansville, WA
Old 01-02-2019, 12:52 PM
CJ in EP CJ in EP is offline
Default What Levi said...
Based on the information provided by Levi a few posts ago, this is how it worked out for my install:
View from the back of the sub panel
View at the front of the sub panel
I'm pretty happy with the result, and the harness on my Stein panel reaches perfectly in this location. Thanks for the tip, Levi!
Chris Hrabe
Eden Prairie, MN
RV-9A
Finishing Engine / Starting Panel
Old 01-02-2019, 01:20 PM
snoop9erdog snoop9erdog is offline
Sent a PM to you Chris
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 01-02-2019, 01:36 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Originally Posted by Mark33 View Post
I’m installing the same unit in my -7 build. I don’t know the exact location that I’m going to install it yet but I think it needs to be in an area that’s readily accessible. Out of all the rest of the avionics installed, the transponder is the one piece of equipment that’ll need to be able to come out on a regular basis to get checked. I’m planning on fabricating a couple of hinged fold-down trays between the sub panel and the firewall on which to mount all of my remote mount avionics, but I think I’ll probably mount the transponder on the bottom side of one of the fold-down trays just so it’s easily accessible/removable.
Does it really have to be that accessible? The FAA-required transponder checks can be done with the unit in place - the only adjustments needed are for altitude encoding and they can be done by front panel programming I bet.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
