Old 12-05-2018, 07:59 AM
Cwood2000 Cwood2000 is offline
Default Prop size
Anyone run a 74 or 75” prop on a 14 tail dragger?
Aka YellaDawg
RV4
RV14 in gestation
Old 12-05-2018, 07:29 PM
Discus2b Discus2b is offline
Order the 74”.
The 72” was needed to satisfy the drop test.
Don’t drop it.
R
Old 12-06-2018, 05:29 AM
Ha Ha, thanks!
Aka YellaDawg
RV4
RV14 in gestation
Old 12-06-2018, 11:07 AM
Don E Don E is offline
Default I chose the 72”
Flying my phase I now behind the recommended 72” prop and loving the performance.
Old 12-07-2018, 12:26 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default My 2 cents
Just my 2 cents, but as always think about your mission. If you compare the same brand and type of prop in a 72" version vs 74" with the same Max RPM on the same plane then aerodynamically the 72" prop should have a higher top speed vs the 74" prop which should have a shorter takeoff distance and faster acceleration. Their is a lot more to it than just that, but that breaks it down to the basic question of which one better suits your mission.
Jon
RV-14A #140512:
Empennage Complete
Wings Ordered
Old 12-08-2018, 05:00 AM
Thanks for the info, I'm having the prop overhauled
Aka YellaDawg
RV4
RV14 in gestation
Old 12-08-2018, 08:57 AM
rv7charlie rv7charlie is online now
There are 76" dia props running without issue on -7s, -7As, & at least one -8 powered by rotary engines. Surely the dia won't be an issue on a -14.
As to speed, the larger dia will definitely improve takeoff performance. And IIRC, when you run the numbers on rpm/dia/airspeed, you have to get a fair amount faster than 200 mph before getting hurt by a 76" prop at Lyc rpms. If it's c/s & you're running down at 2400-2500, like most seem to do these days, the larger dia should have unmeasurable negative effect at speed. For perspective, a Cessna T-210 cruises at roughly RV-speed (faster at O2 altitudes), and runs an 80"+ diameter prop at 2600 rpm.
Old 12-10-2018, 06:03 AM
Thanks for the detail, the prop is in the shop being overhauled as we type.
Aka YellaDawg
RV4
RV14 in gestation
