Old 12-03-2018, 07:30 PM
Bart Bart is offline
Default Step 9-19 final close out
Just curious when people are actually placing the last 6 rivets on the left bottom skin to rear spar. The plans on step 9-19 say to leave open the last 6 but I can't see why or when they should be set and complete the close out. Is it for better access to place the foam ribs? If so, won't it damage the foam ribs setting the last 6 rivets?
Old 12-03-2018, 08:07 PM
AlexC AlexC is offline
Hi Bart - I believe it is part of pg 09-22, step 2, in which you pull the bottom skin down to gain access to the shop end of two AN426AD3-3 rivets. You can substitute MK-319-BS at that stage ... and I highly recommend using blind rivets instead of cramming a bucking bar into the elevator to buck those two AD3-3s. If you use blind rivets, you can close out those other 6 rivets beforehand.
_Alex
Alex C.
RV-14A: Empennage (working on aft fuselage); Wing kit ordered
https://alex-rv14a.blogspot.com
2018 dues paid
Old 12-04-2018, 01:17 AM
Mikeandmaz Mikeandmaz is offline
Hi Bart,
Iíve just completed this stage, now waiting for Proseal to cure. I looked many times for instruction to complete the last 6 rivets you mention but couldnít find any. I just came to the conclusion that with all the rest of the Closeout completed and the next step inserting the foam ribs it was time to do it.
Happy building.
Mike
Empennage arrived
VS completed
Rudder completed
HS completed
Elevators in progress
#140425
Donation paid 2018
Old 12-04-2018, 06:46 AM
Thanks fellas. Mike, I had to laugh at your response because my wife and I decided to do just that.
Old 12-06-2018, 02:35 PM
Swiss14A Swiss14A is offline
Default +1
Hi Bart
Same here, just completed the step and closed it before glueing the ribs in. It is also listed in the list of common mistakes in the other thread (Plan Gottchas).
Cheers
Fabian
Alexandra & Fabian
RV14 HB-YAF, in progress
Old 12-06-2018, 03:56 PM
JokerF22 JokerF22 is offline
I went through that a few weeks ago. I spent SOOOO much time looking through the plans to find out where I was missing that step. In the end, I did the same as you all and riveted before gluing the foam ribs. I wish I could get that time back where I second guessed myself about a million times!
Active Duty USAF
RV-14A Empennage in Work (N410KA reserved)
https://rv14joker.blogspot.com/
