Old 09-05-2016, 04:45 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
Default Shear clip 09-10
Aloha All
Fig 1 step 1, on 09-10 tells us to dimple the E-1022 Shear clip.
I just can not find where it tells us to dimple the corresponding close out tab holes, and at what point those holes are riveted.
Thanks so much for your help
Pete
Old 09-05-2016, 05:34 PM
MED MED is offline
You put in blind rivets in step 13 on page 9-23. You use a blind river, so dimpling the close out tabs is not required. (MED: This is incorrect - dimple them).
If you have one, you should dimple the shear clip with a 120 degree dimple die.
Old 09-05-2016, 05:44 PM
Mudfly Mudfly is offline
Default Good Question
I can't find where the plans say to dimple either. However, look at page9-23, step 13. It refers you to figure 1, pg 9-22. It calls for three (flush) CS4-4 blind rivets. So dimpling would be required on the close-out tabs of the skin as well as the shear clips. I hope that's correct...that's what I did
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2019 VAF Donation Complete
Old 09-05-2016, 05:50 PM
MED MED is offline
I don't see where it says to dimple the rear-most hole in the close-out tab for the blind rivet, but it seems like that would be a good idea. Perhaps, the close-out tab skin is thin enough that dimpling is not required as it was for the shear clip.
You dimple the shear clip in step 1 on page 9-10.
Old 09-05-2016, 06:50 PM
smash smash is offline
I dimpled those holes. They get flush riveted so they won't interfere with the trim tab.
http://www.smashsrv-14build.com
Old 09-06-2016, 08:53 AM
All three holes in the closeout tabs should be dimple countersunk. The fwd two, to receive the dimples in the shear clip, and the aft one for the for the flush rivet.
A future plans revision will address this.
Maybe a Mod. could move this thread over to the plan gotchas thread?
Scott McDaniels
Hubbard, Oregon
Old 09-06-2016, 08:57 AM
MED MED is offline
Thanks, Scott. I just called builder assistance and Sterling told me the same thing. He also said that whenever a flush rivet is to be installed, the skin should be dimpled. The skin is never "thin enough" as I misstated in an earlier comment.
Old 12-10-2018, 09:22 PM
Eztroller Eztroller is offline
So what happens when you dont dimple as per the plans.... any help would be appreciated. Im not pulling this thing apart again. Argh,
