  #31
Old 12-27-2018, 03:55 PM
andrewtac andrewtac is offline
Originally Posted by YellerDaisy View Post
Apologies Bill, I was terribly vague. I was attempting to say that attempts to manually note height and position (using instrumentation and outside visual clues) was too slow/inaccurate. All required far too much attention from this pilot when workload is high and things are happening quickly (wheels up to 50' is 3-4 seconds).
I was really looking for pointers on how a 'common guy' can gather this data with reasonable accuracy (and, hopefully, without investing thousands of dollars). You have clued me into using the GPS track/recording functionality. I can see how this would work quite well. While no longer a pressing issue for me, I will still explore this as I'm a bit of a data junkie. Thank you!!
While not quite as accurate as instrumentation a good flight test engineer could probably get you something reasonably accurate. They did it before orange wire and high speed data. Iíve seen some rather accurate data gathered this way.
Mark Andrew Tacquard
2018 VAF Dues Paid
