Old 01-25-2014, 01:34 AM
ScottSchmidt's Avatar
ScottSchmidt ScottSchmidt is offline
Super Moderator
Default RV-12 RPM, Speed and Efficiency
Today I did some flying and wanted to see how the -12 was in efficiency at different power settings. I need to try this again at a higher altitude where I would typically cruise. I know this is not perfect data and there are more accurate ways of accomplishing this.
I was flying at 5200 ft with an OAT of 32F, only one person and 6 gallons of fuel.
Prop pitch setting would change these numbers between -12's. I would be interested in seeing what others are seeing.
I only measured TAS from the Dynon. WOT (wide open throttle) had a max RPM of 5770.
I will try lower RPM settings to see how efficient the -12 can be.
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1380 Hours)
RV-12 N321UT (Sold)
Old 01-25-2014, 09:25 AM
DonFromTX's Avatar
Thanks for sharing that, very interesting and I too wish others would do the same.
Retired US Army Officer
Old 01-25-2014, 09:44 AM
AZLeeJay AZLeeJay is offline
Nice, thanks for the data points.
Old 01-25-2014, 10:42 AM
N941WR's Avatar
N941WR N941WR is offline
Default Playing with numbers
Let's say you were going to take a 200 nautical mile trip. The time difference between running at 4800 vs 5770 RPM is 25 minutes ( 1.9 vs. 1.5 hours) and the fuel burn difference is .4 gallons (8.7 vs. 10.3 gallons).
Interestingly, if I take that same 200 nautical mile trip in my -9, it will take me 1.3 hours at 150 KTS and only 9.5 gallons burning 7.1 GPH, slightly better than the -12 running full out.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-25-2014, 11:45 AM
The fuel burn seems high. Have you checked your K-factor?
Old 01-25-2014, 12:41 PM
For the altitude Scott was flying at, if you run the engine at right near the max continuous of 5500 RPM, they will typically burn just shy of 6 GPH, so his chart looks pretty close.
Scott McDaniels
Hubbard, Oregon
Old 01-25-2014, 12:45 PM
az_gila's Avatar
az_gila az_gila is offline
Pretty amazing.
To put it in automotive terms, even at the worse point on your chart you are getting 22 mpg at 150 mph...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-25-2014, 12:59 PM
gblwy's Avatar
gblwy gblwy is offline
Thumbs up A couple more points
As it happens, I noted a couple of parameters last week. Slightly lower temperature, one-up, but with full fuel, at 4000 feet, with spats. I've had to translate into your funny fuel units ;-)
rpm fuel speed
4700 4.2 100kt 115mph
5000 4.8 109kt 125mph
5500 5.6 120kt 138mph
Cheers...Keith
Old 01-25-2014, 01:03 PM
NASA515 NASA515 is offline
Keith, what's 5000 rpm in metric???
Bob Bogash
N737G
Old 01-25-2014, 01:08 PM
gblwy's Avatar
Well, for an ex-Lycoming driver it's much too fast in any currency ;-)
Having said that I wouldn't swap my engine - starts in a heartbeat, sounds fine in the cockpit, and people on the ground have commented how quiet the plane is in the air.
Cheers...Keith
