Old 01-10-2019, 06:34 PM
petehowell's Avatar
Default CHT's with Carb Heat
Originally Posted by petehowell View Post
Steve and Doug,
Good catch! I even out the CHTs by applying partial carb heat. On the 3rd run yesterday I turned the carb heat off to see if it would make difference in speed or fuel flow(it did not).
My CHTs are usually within about 10-20deg of each other with the exception of #1 that will be a bit cooler.
I'll get a pic next time I am up.
Went on a Spotted Cow run tonight - this is how the CHTs balance out with a bit of carb heat:
Pete
Amateur Plane - RV-9A N789PH - 2050+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
