Old 11-17-2018, 04:30 PM
AirHound AirHound is offline
Default Heater cable broke
Ok fellas go easy on me. Inner wire broke vicinity friction bends. I didnít build it so does the assembly come complete or do I just order just the wire and try to rethread it through all those bends. Iím guessing order inner and outer complete.
Doug
Old 11-18-2018, 03:47 AM
crashley crashley is offline
Default heater cable
Order a new cable and you then you have a choice of either just replace the centre and if that doesnt thread in easily you can run the new complete cable in
Old 11-18-2018, 10:46 AM
When I installed mine I found that I didnít need the little plate that ďkinksĒ the cable housing for friction to hold the heater door. Removing it will probably make threading the replace,ent cable a lot easier.
Old 11-18-2018, 07:39 PM
Originally Posted by RFSchaller View Post
When I installed mine I found that I didn’t need the little plate that “kinks” the cable housing for friction to hold the heater door. Removing it will probably make threading the replace,ent cable a lot easier.
Thanks Rich, will give it a go again. Last winter here in your old stomping grounds the heat was needed and the door wouldn’t stay open so I had to install/adjust that plate. The intake air pressure is pretty strong to stay open without some friction/more like binding/ force at play. Maybe The newness will work without it though, no big deal.
Doug
Old 01-08-2019, 05:44 AM
gblwy's Avatar
gblwy gblwy is offline
Default Snap, in more ways than one
Mine has just broken too. How much did the replacement cost? Did you manage to just replace the inner piano wire?
Old 01-08-2019, 07:17 AM
Scott Hersha Scott Hersha is offline
Bowden cable wire only (.65/ft):
https://www.aircraftspruce.com/catal...clickkey=13351
Bowden cable housing and other parts:
https://www.aircraftspruce.com/searc...bowden%20cable
Complete ratcheting cable assembly 41 - 50$: (depends on length)
https://www.aircraftspruce.com/catal...?clickkey=5322
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 01-08-2019, 07:51 AM
JBPILOT JBPILOT is offline
Default This is a lockable control cable
https://www.oreillyauto.com/detail/b...l+cable&pos=20
I have used one of these for years. Excellent. Locks firmly with a slight twist of the T handle.
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-4-18 )
Old 01-08-2019, 11:50 AM
Default Broken Heater Cable
If retaining the knob placard "PULL/ON" concerns you, then order whole new cable from VANs and just use/insert/feed new inner wire thru old cable, and unscrew old knob with placard to put on end of new wire where you will have to unscrew the new knob...Otherwise, leave new wire and new knob alone, just insert it into old cable, and also buy the VANs RV-12 sheet of placards and placard the new knob with "PULL/ON", again if placarding is a factor for you....
Doug
Old 01-08-2019, 12:14 PM
DaleB's Avatar
DaleB DaleB is offline
If you need a placard for a new, un-marked cable...
https://www.aircraftspruce.com/categ..._zinserts.html
Dale
Omaha, NE
Previous RV-7 project (sold)
