Old 01-04-2019, 06:17 PM
mmoran mmoran is offline
Default RV7 Instrument Panel
Has anyone ever shortened the bottom of the 7's instrument panel?. My wife loves to fly with me and I'm building a 7. The instruments panel is low and makes it very difficult for her to get in.
Old 01-04-2019, 06:58 PM
wirejock's Avatar
wirejock wirejock is offline
Default Extended panel
Low? Is it possibly an extended panel?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/27/2018. Plus a little extra.
Disclaimer
Old 01-04-2019, 07:32 PM
kevinsrv7.com's Avatar
kevinsrv7.com kevinsrv7.com is offline
No but I do recommend placing your power levers on the panel instead as shown here.
http://www.kevinsrv7.com/hannahpanel1.jpg
www.kevinsrv7.com
Old 01-05-2019, 08:27 PM
sglynn's Avatar
sglynn sglynn is offline
Default Panel Position Seems Too Close
Does the RV-7A panel seem close or almost in your face? I've been hangar flying getting ready for first flight and with the seat cushions in I feel like I'm too close to the panel. Pedals are okay. Seat is all the way back. The seat seems to vertical too, like it should be tilted back a little. Any suggestions? (Other than I'll get use to it.)
thanks
Steve Lynn
RV-7A
100% Complete
Airworthiness Certification Complete
First Flight in January 2018
Anacortes, WA
www.mykitlog.com/sglynn
Old 01-05-2019, 09:23 PM
pilotkms pilotkms is offline
The Antisplat Almost 14 Mod provides a nice reclining angle. Great mod - inexpensive at $180 and relatively ez to install if u built the plane.
Keith
RV 7A RV #9700
N325KS the Flying K
Built in SoCal KCCB, now @ KPXE
250+ Hours & 5x cross the USA
2018 OSH - yes
Old 01-06-2019, 12:43 PM
Ralph Inkster Ralph Inkster is offline
If you have sufficient head room, you could also try a spacer under to seat cushion to raise you above the panel. You could try a 1" ridgid styrofoam panel under there to see how that feels.
For a real panel in your face experience, try out sitting on a Rocket or RV8.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 01-06-2019, 12:50 PM
Tankerpilot75 Tankerpilot75 is offline
To pickup on the Antisplat comment, you might also consider additionally adding the new Easy Exit bar @ $89. Both the Almost a 14 and the Easy Exit Bar modifications should address any entry, exit and seating position concerns you might have.
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, GRT EIS, Garmin 340, 335, Dual 430s, FlightBox hard wired to WS, Dynon D10A with internal battery (backup EFIS)
Retired - Living the dream - And going broke!
Old 01-13-2019, 09:14 AM
My thought was that by raising the bottom of the instrument (by cutting it off of course) it would allow more room for bending ones leg. Long flights, leg cramps, etc. I haven't finished the build yet and I am still contemplating the panel layout. With todays avionics there is more than enough real estate (in my opinion) for all that I would need.
Old 01-13-2019, 09:31 AM
rsr3 rsr3 is offline
I plan on doing the same - minimalist panel using modern instruments should allow for maximum legroom. In my experience, you can never have enough!
