Old 01-03-2019, 07:33 AM
paul330 paul330 is offline
As mentioned, you need to test to find your own numbers, Also bear in mind that whatever you come up with, these are theoretical numbers. It is generally preferable to fly slightly on the fast side for several reasons:
- it makes little difference to the glide angle
- helps with any headwind
- further from the stall especially as some heavy maneuvering might be required
- leaves a bit more energy for that final glide to touchdown if you are a bit short
Paul
Mercy Air, White River FAWV
ZU-IIZ - "Zeus"
2018 Donation Made
Old 01-03-2019, 08:49 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Default Best glide
I would add that it gives you a little margin for the natural tendancy pull up as you speed towards earth without power.
Been there!
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
