Old 12-10-2018, 08:45 AM
Default Just me
Mine came out exactly like Bruceís . This thing gets sealed with tank sealent anyway and I figure that will cover the hole. I dont see a need to maintain this rivet.
Dont forget the washer between the main gear and spar. It is best to fit it now while the botom skin is off. Some washers may need trimming.
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 12-10-2018, 09:15 AM
wirejock's Avatar
wirejock wirejock is offline
Default Gear weldment
Originally Posted by Draker View Post
Thanks for the info. Larry, did you fit everything by grinding away powder coating from the gear socket? I don't see how to maintain edge distance here, given how far this thing has to go before seating against the center section.
No. I didn't touch the weldment. Just kept working the skin and flange. I used a dremel with a grinding bit. Lots of putting it on and taking it off till it fit perfect. I'm sure they are all a little different. Maybe I got lucky. Worth a call to Van's but I think that hole can for removed if necessary.
I assume you figured out the two or three nutplates have to be removed to get the gear in place. Also, remember the washer.
The other item to check is interference with the wing bolts. Mine were an issue. The drift pins would hit the gear weldment hole. I had to file the holes a little (Vans Advise). Last thing you want when it's time to mount wings is bolt interference.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/27/2018. Plus a little extra.
Disclaimer
Old 12-10-2018, 09:59 AM
Raymo's Avatar
Raymo Raymo is offline
Consider that the skins in this area are likely the same for tail or nose dragger. Losing a couple sheet metal holes around the weldment, which vastly strengthens the area, won't matter.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 12-11-2018, 12:52 AM
Draker's Avatar
Draker Draker is online now
Thanks, Larry. Yes, Van's confirmed too: Make the gear fit and forget about the hole.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 1/2/2019
RV-7A: Empennage and wing kits complete minus fiberglass, fuselage in progress!
Old 12-27-2018, 11:15 PM
Draker's Avatar
Sorry, What washer? Studying the drawings I donít see any oddly placed washers.
Ryan Drake
Livermore, CA
Donated 1/2/2019
Old 12-28-2018, 08:18 AM
jcarne's Avatar
jcarne jcarne is offline
Look at spot A4-5 on the drawing and read that big block of text pointing to the one bolt. One washer goes between center section and gear mount.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
Old 12-28-2018, 08:23 AM
Default Me to
Yup, one washer had to have the edge filed to fit right, the other side was ok as is. I taped these to the spar so i wouldnt lose them when it comes time to final install.
Also, when trimming for the gear and “loosing the hole” i forgot to include the space need to tighten the gear. Mine just fits, but i think i will need to grind more for “sinch up” room. Thanks for the warning, mr “wire jock” larry. Just in time too, I am about to flip the canoe.
John S
Fuselage 30%
