Old 12-21-2018, 08:54 AM
John-G John-G is offline
Default Van's RV-12 winterization kit
The Van's winterization kit for the RV-12 has been available for almost two years now ... so hopefully someone can answer my question regarding the use of the three oil cooler covers.
What has your experience been regarding temperature ranges (based on ground temperature) that best suits the small, medium and large oil cooler covers?
I believe I read a post a while back stating at 35° F OAT the small oil cooler cover worked well and kept the oil temperature around 200° F ... but I don't remember reading anything about the other sizes.
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2019
Old 12-21-2018, 10:44 AM
John
I have only used the largest oil cooler plate. OAT was 37F at 2700MSL and oil was stabilized at 212F.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 429
LSRM-A Certificate 2016
and MJ Stricker (Flight Instructor) - 1st Lt./Captain B-17H
Old 12-21-2018, 10:54 AM
I believe I read a post a while back stating at 35 F OAT the small oil cooler cover worked well and kept the oil temperature around 200 F ... but I don't remember reading anything about the other sizes.
The reason there are 3 covers is because every engine has a specific oil temperature personality.
I have installed a different engine on a flying airframe and seen totally different oil temperatures in the same oat conditions.
Because of that, you can't necessarily use a specific recommendation from a different RV-12 owner, and it is why the instructions are written the way they are (instructing to experiment... starting with the smallest and see what the result is.
Scott McDaniels
Hubbard, Oregon
