  #51
Old 11-09-2018, 04:08 PM
Bavafa Bavafa is offline
I have looked at it and debating to do it at this time or leave it for a bit later. One rivet might pose a bit of challenge the one immediately aft of the rib. I might barrow a friend's pneumatic squeezer for the rivets inside so it can be a one handed operation (if that is possible)
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-23-2018, 09:33 AM
RV-14E's Avatar
RV-14E RV-14E is offline
Originally Posted by RV-14E View Post
Greetings.
Please see this VAF post for examples of cracks on a flying RV-14 (not RV-14A).
Here are the parts contained in SB 18-09-17. Rounded forward, blunt aft and beveled edges are apparent on F-14148A Skin Doubler. Remember to countersink F-14148A/C to accept the dimpled J-stiffeners.
I will be installing these during my annual in two weeks and will report back with my experience. My airframe has 87.6 hours, is flown by a pilot who prefers boring flights and shows no indication of cracks in the area associated with the SB.
My friend and I completed the SB on my flying airframe last week. It took about an hour. You can read about the details here: http://rv-14a.blogspot.com/2018/11/m...ttom-skin.html.
The AD3 rivets called out for in the SB were too short. Every AD3 rivet I used was 0.5 larger. When you place the rivet in the hole, this need will be immediately obvious to you if it applies (my use of primer may have contributed to this need), but I suggest bringing your rivet sizer with you when you crawl back in the tail.
I used drilled out rivet heads as filler for the exterior dimples.
Access wasn't tough. I used boards in the baggage area and lots of padding in tail.
Install was straightforward
E
Old 11-23-2018, 10:36 AM
control control is offline
I did mine earlier this week. Did everything exept the riveting by myself. I needed 1.5 hours to get it done (I primed )
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 11-25-2018, 12:12 PM
TimO TimO is offline
I am glad you brought that solution of drilled rivet heads up. I was going to mention that a week or two ago. I think that's what I did on the firewall when at the time there was the discussion about drilling vs dimpling the battery bracket or something like that. I just drilled a bunch of rivets and used those to fill the dimples. This should work well for the belly and that doubler.
I haven't done mine yet. I've got some paint to test for color match and then I may do it, but I may wait until spring when it's warm enough to paint while it's on the plane. That way I have painted rivet heads. There won't be that many hours of flying between now and warmer weather.
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1375+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 300+ hours http://www.MyRV14.com
Old 11-25-2018, 06:02 PM
iamtheari iamtheari is offline
I decided not to try to fill the dimples. I didn't take pictures since the pictures in this thread are already excellent. The tailcone was not attached to the fuselage yet, so we opted to lay it on its side on a workbench. The side skin is flat enough that this fully supported it and let us reach in to to the drilling, parts placement (with a cleco buddy outside), and riveting (with a bucking buddy reaching through the aft deck for the AN470AD4-4 rivets). Total time was 0.6 hrs solo to prep and prime the parts and 0.8 hrs with a buddy to drill and rivet everything. And as a bonus, we clecoed the tailcone to the fuselage afterward, and earned an extra build beer each.
Happy building, everyone!
Old 11-28-2018, 06:25 PM
Jake14 Jake14 is offline
anyone use pop rivets/cherrymax for this? I'm tied down far from power sources. Maybe even a bit of proseal on the faying surfaces?
RV-14A #140158 flying
Old 12-08-2018, 09:20 PM
MonkeyWrench MonkeyWrench is offline
Default SB 18-09- 17 Done
I think the SB calls for shorter rivets than should be used.
Had to upsize the AN426 rivets: AD3-3.5 to AD3-4 and the AD3-4 to AD3-4.5.
I still have one of each of the original size called for in the SB, but may drill them out. Just a little too flat.
https://www.vansaircraft.com/pdf/ser...sb18-09-17.pdf
I had already dimpled my skin, but just pressed them flat with the DDRT.
Rich
RV-14A
working on empennage
EAA Chapter 186
Old 12-08-2018, 09:39 PM
I agree, specially if it is painted airplane. I had to upsize all of them.
Mehrdad
Dues paid
Old 12-08-2018, 10:46 PM
Unless you use this for the shop head size specification
https://www.vansaircraft.com/public/Specs.htm
Scott McDaniels
Hubbard, Oregon
Old 12-11-2018, 07:23 PM
Andrewal Andrewal is offline
Default Get a long, skinny rivet set
I just finished SB-18-xx-xx. Drilling out the rivets from below/outside was taxing on the arm muscles, but not difficult. I have learned to use a slightly smaller bit to drill out rivets... and I've now drilled out more than I thought I would. There are a couple of rivets inside the tailbone that can be squeezed, but the 470 "clip" rivets must be bucked due to the bulkhead flange. There are rivets in the bottom skins that are too close to the bulkhead for a standard rivet set head to reach on the inside. If you want to back-rivet them, you'll benefit from a thinner (high risk) rivet head for those. My bak-rivet head couldn't get close enough to the bulkhead. I've been lucky to have a good friend who will buck rivets for me from the outside... and a great wife who will do so in a pinch.
Andrew Alexander
EAA Chapter 1
