The hose connection is leaking at the banjo fitting. There is a tight 90 degree bend on that line, and it has a lot of stress on it. I've made a temporary fix, but I need to order a new line. Anyone else have this issue?? Actually, it was not easy to find. It only leaked when the engine was running. Just running the electric fuel pump with the top cowl off did not show the leak. My guess is that vibration played a part. I did notice a small fuel stain on the belly. Running it with the cowl off was not a lot of help, as the prop wash distributed the fuel in a fine mist on the windshield, but I finally tracked down the source. I wonder how long this has been going on?? Maybe I just got a defective hose.
Tom
Tom
