I learned that the really nice aluminum wheel chocks I own aren't going to work with the wheel pants on my RV-12 because they are too tall. Any sources or suggestions for low profile wheel chocks besides the 1.5" poorly rated low profile wood chocks from Sporty's?
Why not grind them down?
you can purchase 2 feet of 1" X 1.5" X 1/8" 2024T3 aluminum angle from Spruce @ $7.65 per foot (part number 03-47400) and make your own set of 6" chocks that will work great... You can drill a small hole near one end of each chock and slip through brightly colored water resistant (thin) rope and you've got your two sets of chocks.
Mel,
This is off topic but have followed your posts for a while and would like details on your 0-320 rebuild. Know you're at OSH, when you get an opportunity. I have a couple of mechanics who are very willing to oversee my work. Looking for info on which cylinders, pistons (9-1), connecting rod prep. Currently the engine has dual Lightspeed ignition, no vacumn system, lightweight starter, and rebuilt carb. Thanks for your consideration.
Mark Weber
