I now have about 30 hours on my -12. I originally set the prop pitch with the #3 gauge supplied with the propeller. My static RPM was close to where it should be and I was satisfied with the overall performance of the airplane.
A week ago I ordered and subsequently received the new TOOL-00002 to help 'fine tune' the pitch adjustment. Firguring it had to be better, I went ahead and reset the pitch exactly as outlined in the newly revised section 47 of the KAI. When I got done, both blades measured 71.4 degrees on repeated checks.
After the adjustment, my static RPM was in excess of 5200. My cruise performance also took a bad hit. I guess I should not have messed with my original settings and success. Tomorrow, I'm going back to the original settings.
Has anybody else run into this issue using the new tool (and the 71.4 degree setting) or did I fumble this some how?
Alex
Alex
