rmartingt
Following the build manual, it calls for test-fitting and drilling the rudder pedal assemblies while the fuselage is still upside-down. Then, removing them and storing for later.
Is there any reason this can't be done later, just after it's right side up? I would think that fitting the pedals would be something best done when you can sit in the seat and check the distance. I don't want to be trying to guess where they should go and then just have to redo it later on...
