Old 01-01-2019, 06:55 PM
Jvon811's Avatar
Jvon811 Jvon811 is offline
Default Missing piece? F-466 Trailing Edge Fillet???
A friend of mine recently purchased an RV-4 and after getting it home and further inspection, we've discovered his airplane is missing a part that mine has... It's the fillet between the fuse/cockpit area and the tailcone of the airplane.
I went back, looked at my set of plans and sure enough, there it is, F-466. My question is, how many (if any) RV's are flying around out there without this? Is is structural or purely a cosmetic/aerodynamic piece? My RV-4 does have this F-466 piece and it seems to have 15+ rivets holding it on making me wonder if it's structural. If nothing else, it gives my friend and I a reason to bend some sheet metal and learn some building techniques.
-Justin
RV-4 N249P O-320, Warnke Prop, GRT Sport EX
Old 01-02-2019, 06:00 AM
Default Just a fairing
It is simply a transition fairing with no structural value that blends the "square" fuselage to the radius of the belly skins . You could make and install one using solid or blind rivets. If I recall, its only .020" or .025" aluminum , but gives a nice clean look and better aerodynamics.
Bill E.
RV-4/N76WE
8A7 / Advance NC
