Bsquared
Just finished drilling and installing nut plates on my -14A Wing tips. Not sure what moved but when I put the 2 alignment jigs back on the right wing the tip is slightly out of line with the trailing edge.....3/16? low. I am not a fanatic so I can live with it if it will not cause any performance issues. The option is to split the T/E of the tip and re-align it. Thoughts? Remember, this is a 14. I know a lot of folks will say that you should wait until the wings go on to fit the tips but I am building to the plans and the jigs and tooling hole are there for a reason. I probably let something move when I was match drilling the tips
