Engine PreOiler: How-To
Here's my ACE brand engine pre oiler. Made mostly out of PVC to save cost, with brass fittings where needed.
Total Cost: $42.00
Main Body
The Main Body is 3" Sched 40 PVC pipe. OD is about 3.5" with a .216" wall.
The upper end of the MB is fitted with a threaded coupler that's glued on, and has internal threads for the cap.
The lower end of the MB is fitted with a plain cap, glued on.
Top Cap Assy
The Top Cap is the black plastic part, and has a hole drilled through it to accept a threaded brass bung that seals with a rubber washer. I used a pipe thread adapter to reduce the threads to what my shop air fitting would screw into.
Bottom Cap
The Bottom Cap is just a plain PVC cap, glued on. It also has a hole drilled in it to accept a bung similar to the one used on the top cap. Brass fittings are used to adapt from the bung to a ball valve, then to a nipple for the clear flex hose. The other end of the clear flex hose has a standard 1/8" male pipe fitting that screws into the back of the engine.
The place we hooked up to the motor, in the last photo, is where the stainless braided hose is connected, just to the right and just below the vacuum pump pad. Depending on your engine, there may be alternate ways to do this.
To use, just connect to the engine, and close the ball valve. Pour a couple quarts into the PreOiler, then screw the top cap on. Connect the shop air, and set to about 40 psi. Then open the ball valve, and whalla! Oil will flow through the upper engine galleries with gusto.
We put 4 quarts into the motor with the PreOiler, then 4 more down the stick. Spun the engine on the starter (plugs out) and we got instant oil pressure. Then we fired it up for a nice smooth start.
Disclaimer: Schedule 40 PVC isn't exactly real good stuff to use in high pressure situations. The 3" stuff is rated for 260 psi, but who knows about the bottom & top caps on this thing. Be cautious about how much pressure you use. We found 40 psi did the job: a little slow, but did it just fine.
