Old 03-20-2018, 07:40 AM
Vlad Vlad is online now
Default Educate me about vacuum pump
I just got a nice gift a set of clean low time vacuum driven gyros (thanks JohnR) and I need a pump and associated plumbing. How long usually vacuum pump last? Used or new? Please educate me.
Old 03-20-2018, 08:04 AM
dlloyd3's Avatar
dlloyd3 dlloyd3 is online now
Went thru about 10 of 'em in the Bo. About 600 on the average. Two failed under 100 hours. Seems like one went 1200 hours.
Dave
RV-7 Tipup, Flying, I0-360,
Hartzell, Dual Skyview
Old 03-20-2018, 08:12 AM
terrye terrye is offline
Default Vacuum pump
Well, the wet vacuum pump in my Cessna 150 has lasted over 30 years that I have owned it, and maybe longer than that. On the other hand I have heard that dry vacuum pumps are prone to self destruct at any time up to around 500 hours.
Either pump has a main rotor with several vane slots in it. In the case of the wet pump, the vanes are steel and the pump is lubricated internally with engine oil. The discharge line from the pump goes into an oil/air separator with the oil being returned to the engine sump and the air discharged overboard. The dry pump was an "improvement". The vanes are self lubricating carbon/graphite and thus the pump is "dry", that is it needs no lubrication from the engine oil and needs no oil/air separator. BUT, the vanes are more fragile and do not last anywhere near as long as the wet pump.
After understanding this I decided both technologies were obsolete and I'm making my RV-9A fully electric with EFIS displays.
Terry Edwards
RV-9A (Fuselage)
2018/2019 VAF Contribution Sent
Old 03-20-2018, 08:42 AM
RV6_flyer's Avatar
1st one in the RV lasted between 700 and 800 hours. 2nd one lasted almost 2,000 hours. Third one was removed working with between 600 & 700 hours.
I overhauled the 1st vacuum pump and still have it sitting on the shelf. If you want it, it is yours.
Vacuum system removed from my RV-6 less than a year ago to upgrade to two G5s and GMU 11.
Both gyros sold through VAF. Not much of a market for vacuum stuff in the experimental world.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 03-20-2018, 09:23 AM
noelf noelf is offline
Vlad, I removed the vacuum system from my Cessna 150 that I recently purchased and installed the Garmin G5 AI and HSI units. I do not know if the pump was working, but you can have it and the vacuum regulator and filter if you want them.
I will be in Mount Holly next month for several weeks and I can bring them up there if you want. The 150 is in a hangar at Flying W.
Noel
RV-6A N6NF
tip-up
flying
Old 03-20-2018, 05:02 PM
BobTurner BobTurner is online now
The graphite vanes should be good to TBO/2000hrs, but, as others have said, they are very sensitive to FOD. Anything that can impede their smooth sliding along the wall can break a vane. Make certain you clean everything (gyros, hose, pump) prior to installation. Early failures are often blamed on small carbon chunks from the previous failure getting sucked into the pump.
Old 03-20-2018, 06:16 PM
FORANE's Avatar
FORANE FORANE is offline
Get a sigma tek. they are built way better with a metal vane holder and vanes that are strong like carbon fiber. compare that to the fragile carbon like pencil lead vane holder and vanes in a different brand such as rapco.
Lancair 235/320
RV-9A (2013 - 2016)
Old 03-20-2018, 06:48 PM
RVDan RVDan is offline
From the Malfunction database that I revised a few years ago the dry pumps have an MTBF of about 500 to 600 hrs. That said, If you decide to go head with a vacuum system, I have some of the other components, like fittings, filter and regulator if you need them.
Dan Morris
Frederick, MD
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 03-20-2018, 07:34 PM
sibriggs sibriggs is offline
Default Vacume system :-(
Vlad, I used vacuum systems (gauges, pumps, gyro's) for years. My advice would be to sell the items you got and use the moneys to help buy an electronic replacement, G5 or similar. You'll spend a bit more but it will pay off in the long run and be much more reliable and provide additional flight info.
Steve
Steve Briggs. RV9, G3x, G5, VPX, GTN625, PMags, A&P, IA, ATP-CFII
Old 03-20-2018, 09:02 PM
Rallylancer122 Rallylancer122 is offline
Steve
Ditto what Steve said. Most people consider dry pumps to be on borrowed time after 500 hours, but it's not uncommon for them to fail before that. I was at an AOPA seminar a couple years ago and they threw up a stat that something like 1/3 of all vacuum pump failures in IMC are fatal. That was enough to convince me they weren't worth messing around with.
DEM
