Old 04-03-2015, 01:17 PM
Jake14 Jake14 is offline
Default fairing nut plate locations
On page 10-20 there is a nut plate location next to the leftmost nut plate and another one off the picture. The instructions don't show nut plates in those locations, but looking at the fairing installation section, it looks like nut plates are needed in those locations. What am I missing?
Old 04-03-2015, 04:05 PM
Those screw locations correspond to the fiberglass empenage fairing which needs to be match drilled using the holes in the aft fuselage, so the nutplates do not get installed until after that has been completed.
Scott McDaniels
Hubbard, Oregon
Old 04-05-2015, 08:28 AM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default Emp 10-27, Rev 1 rivets?
regarding 10-27, Rev 1,
I have a feeling you are correct.
I will look into it on Monday.
Is the correct rivet FLUSH ????
I am about to get to this point on the emp.
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/2/18 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
!! I SURVIVED RIPON ARRIVAL - KOSH 7/21/2018 !!
Old 04-05-2015, 11:06 PM
Sorry, I forgot to follow up on this.
470AD4 rivets is correct..... there is no reason for flush rivets in this area ( a future plans revision will reflect the change).
Scott McDaniels
Hubbard, Oregon
Old 05-22-2015, 02:58 AM
control control is offline
I will soon be at this step (17-03) and do not fully understand the remark. My plans and the revisions that exist at Vans have not been updated for this section.
Am i right in asuming that you should make it 59 3/8 but make sure to start from the inboard side and you will be ok?
Wing pg 17-03 Step 4 The plans say to cut the J-channel to 59 3/8 inches. I and other, but apparently not all, have found this is too short as the end of the J-channel will not have sufficient edge margin for the last rivet Tom023 Drilling the single J-stiffener hole 5/8 from the inboard most edge of the J-stiffener on both sides and clecoing the inboard most J-stiffener hole instead of the outboard most hole should remove this problem. The length of 59 3/8 is correct. Rev 1 of page 17-03 and 17-04 will depict this -AB (Older Comments below) Recommend waiting to fabricate the J-channel until you have the skin and ribs assembled in the stand so a proper measurement can me made. Following Vans plans will definitely cause you to be short. AB
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 05-22-2015, 06:21 AM
Mike H Mike H is offline
I cut my J channel stringers about 1/4" longer than the plans, then trimmed the long end after locating and match drilling. If you cut it per plans it will barely have ED on the most inboard and outboard rivets.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
Old 05-22-2015, 02:39 PM
Smile
Got it, thanx
RV-14 kit #140138
Old 06-05-2015, 09:43 PM
SantaRay's Avatar
SantaRay SantaRay is offline
Smile Getting started
I am getting ready to start building the RV14 in a couple of weeks. Thanks to all those posting the gotchas. That is some really good info that I am sure is going to come in handy!
Old 06-05-2015, 10:03 PM
Hopefully it won't even be needed.
As early builders found plans errors, corrections were made.
Scott McDaniels
Hubbard, Oregon
Old 06-06-2015, 05:10 AM
TedsNumberOneSon TedsNumberOneSon is offline
Default RV14 build
John, welcome aboard. I have a 14 tail kit in progress in East Orlando by UCF. Private message me and we can connect. Having another 14 in town will be a good thing.
Terrell Yon
Orlando FL, KCOI Merritt Island Home airport
140173 Kits Underway
Tail kit structurally complete
Wings in progress
N87TY on hold
EAA 724 and 74 Member
