Fuel flow transducer mount question
mturnerb
The plans specify "high temp" adel clamps for mounting the transducer. Van's sent me regular clamps in the required size.
Has anyone else run into this issue. I would have called Van's but they're closed today and I'd like to get past this.
Thanks in advance
I have several regular adel clamps attached to the RV6's sump. No problems in 18 years. I'd use what Van's supplied and move on.
Thanks in advance
The important requirement is that the have stainless steel bands (not aluminum).
The ones you got in your kit should be stainless steel.
