HeliCooper
I'm fabricating the aileron actuation on page 23-03. The manual says to sand the VA-111 to a tight fit inside the pushrod. With only sanding the inside of the tube to debur the drilled holes the VA-111 is sitting inside the tube pretty sloppy. My concern is when I match drill the tube to the rod end the rod end could end up on an angle. Anyone with more experience have a suggestion here or am I worrying over nothing?
Jim
Jim
