RV-8 with ground adjustable pedals. Rear seat pedals deflect the rudder to the stops - no problem. Front seat pedals do not. However, if I disconnect the brake cylinder from the pedal I get full deflection to the stops. So, I surmise a problem with the cylinders and/or the way I've installed them. Sent pics to Vans - no help. Hopefully one of you will see the error.
Deflection should be 2" from elevator - more like 4" with brake cylinders attached.
Help!
Help!
