Sec 5-6 in RV-12 POH shows range or different altitudes. It really pays to cruise up high and to answer your question you need to qualify at what altitude.
Personally, since I try to get above 7,500 for longer trips, I plan for 122 TAS, @5,450 RPM and 4.8 g/h. Fuel is cheap these days so I'm not an economy guy of late.
I tend to plan for 110 to account for ground time, climb, pattern etc. But 115 is a realistic enroute speed.
Turner, how are you enjoying that new SLSA? How is the Garmin G3X Touch?
Brent, I'm jealous - I'm seeing no more than 115-118 at any altitude below 5500RPM. Are you using the standard (Sensenich) prop?
Factory supplied Sensenich prop. Pitched exactly in range that Van's PAP recommends - in fact I know of some guys that are more aggressive with the pitch but I like the balance I have between climb and cruise. Did find that adding the wheel pants added several knots at cruise (assume you have those already). Routinely see 124 kts TAS on the Skyview in smooth air in fact. When its a little turbulent (which for an LSA doesn't take much) I do throttle back as the RPM will swing above 5,500 as the pitch moves up and down on autopilot. But on those smooth air days I'm as close to 5,500 I can get.
