I have the combo
O-360 and a Harzell HC-C2YR-1BF CS prop
Now I am looking to find out the most economical combinations of
MAP / RPM at altitudes, ie 2,4,6,8000ft
I try to understand the Lycoming owners manual, and it seems perfectly ok to go significantly under "square".
So I would like a chart in the cockpit with recommendations, ie at 4000ft, what is a good MAP / RPM combination to achieve 55% power.
