boomer
Has anyone checked SB 518D ( http://lycoming.com/Portals/0/techp...SB518D Oil Cooler Bypass Valve Inspection.pdf ) to see if it applies to the IO-360-M1B? Thanks.
-John
-John
Hello,
does anyone have more information about this? The link to the Lyco document does not work.
I'm interested in more information about which seal does it need, so I can organize a new one before I take it apart, and how much torque I need to install it. Looks like Bavafa found the torque which seams to be 300 in.-lbs.
Dominik
Hello,
Dominik
Hello,
Dominik
...mine has NO markings of any kind on the top, even lightly sanded it to see if there was something painted over etc.
.....any thoughts on that? were non-Lycoming vernathermii commonly used?
I remember some pilots group trying to find a source for non-aircraft vernatherms.
IIRC at that time they couldn't find an alternate non-aviation source, or even who made them for Lycoming.
I will be very disappointed to see the need to address a 1972 original issue SB on a 2010 new Lycoming. While I do not know this for a fact, one would think that ADs and SBs prior to manufacture date are complied with. Any other path would seem legally stupid.
For your engine (which I have the same) the valve is located at the bottom pointing up. During your next oil change when you remove your oil filter, take a look at the bottom part and you should see it. Of course it can also be seen with the oil filter in place only not as easily.As I look at the description and drawings here:
https://www.google.com/url?sa=t&rct...on.pdf&usg=AFQjCNFFC2tAq_0FDBHyXjS1P0aPNs-v1w
which is SI 1008C,
my -M1B has a spin-on oil filter in this location.
Am I mistaken about this?
Merrill
Anyone know the socket size for the Vernaterm. It looks larger than anything I'm likely to have in my toolkit...
